brianrbull
- 10
- 18
- Casnovia Michigan
Yes It stops the fuel there by shutting down the engine. I would recommend repairing it as using the clutch to stall your engine is a "Brutal" way to do it and will result in rapid clutch wear and possible driveline damage. I will be home in a week I can give you a hand with it then if you would like. I am going to be "Testing" my new 816(Wrecker),818(Tractor),1028(Contact Truck)'s when I get home......Should be a good time. got some decent hills "Out Back" and if we get stuck well....There is always the wrecker.....I am also PRAYING for a LOT of snow...........Anyone else from the GR area wanna play let me know
