Vinyl cover revitalizer.
DREDnot
602
Phoenix, AZ
I have great results with the CARC substitute spray paint on the vinyl parts and to touch up the body.
The body paint I then coat completely with WD40 inside and out. Looks like new.
Your paint on the body looks great and will be perfect with the WD40 treatment.
DREDnot
602
Phoenix, AZ
Military uses diesel fuel when they need to look nice for inspections.
WD40 seems to last a little longer.
I buy it in the gallon can and apply it with a hand spray bottle.
It has similar benefits as oiling a gun prior to storage.
Tires get a few coats of PB Blaster Silicone Spray. It doesnt evaporate as fast as other brands and soaks in. It protects the tires from dry rotting/UV deterioration and makes them easier to clean. I also use the silicone spray on anything flexible or rubber.
Once soft doors and top vinyl is painted I'll give them the silicone treatment as well. Freshens up the rubber edges of the soft doors and keeps the vinyl from drying out and cracking. The silicone is also the best for lubing the windshield channel prior to pulling the front edge of the soft top through.
GeronimoK9
Graham, WA
DREDnot
602
Phoenix, AZ
No markings whatsoever on the rear of the trailer.
Just a USMC serial number on the tool box and the storage markings on the front of the right fender
