bcowanwheels
- 3
- 18
- KINGSPORT, TN.
m715 axles rebuild & d70 'correct" power lock
THOUGHT you fellas might like to see a correct (.500 or 1/2" offset) m715 dana spicer 70 series power lock 23 spline ( 2 piece axle gears) . these things are extreamly rare. they havent been made in over 20 yrs and there is no parts left for them anywhere except for the clutch packs. dana spicer only has steel/steel clutches now as they lost there fiber clutch mfg. heres a N.O.S unit on the left, stock open carrier in the middle and a p/l carrier half I,am rebuilding on the right. also a set of axles I,am rebuilding for a fella who wants power locks front and rear, 4.56 gears, lockout hubs along with normal complete strip down and bring back to new spec's axles hub to hub. A power lock is alot better for a m715 that see alot of highway miles as it dont have the harsh characteristics of a locker in the rear so tire wear is about 1/2 compared to a locker. in one of my m715's i only got 9k miles on a set of new rear tires and I knew to let off the gas going around corners, enjoy. more to come on this.
bob
bob
