Warning Lights - Oil and Temp. HOW TO TEST SENSORS?
MuddWeiser
Truckee/CA
M1009. Lights come on (key on engine off) as normal. Since I have the motor torn apart waiting on Injection Pump rebuild - is there an easy way to test the sending units for these lights?
I KNOW I have had this thing overheat before... Was blowing black smoke for 20 minutes up a 4,000 mile increase in elevation... I thought for SURE that light would of come on...
While I try to pay attention to smoke and engine load to protect from EGT - it would also be nice to KNOW that my light is working to give me that extra "reminder" .... Especially since I daily drive around 7k - 7500 ft elevation.
ALSO - Where are these sensors located???
rnd-motorsports
Evart,Michigan
The temp sender for the warning lite is one the driver side front corner. its a sender that is a grounding switch if you will when the temp reaches about 225/250 best bet for the cost just replace it also the oil sender is on the backside of the block on top driver side of the vac pump again no real test a grounding swicth at I think about 5 psi or so if you think its bad replace. Just so you know the sender on pass side rear is the glow plug temp sender. I dont like the lites I install gauges in all my cars/trucks I like to see what temp and pres is at a glance 2cents
MuddWeiser
Truckee/CA
RND-MS, THANKS FOR THAT...
Westech, I know I could probably spend the 30 minutes pulling up the TM and tracing it out -- but there are so many 1009 owners on here that sometimes it's better to ask, . chances are someone has dealt with this already and knows exactly what the issues are...
For Example: heater blower motor troubles... Does the TM reference the fact that the blower motor switch is prone to melting? NO. But chances are your switch is melted :) I just use that as an example of something I fixed a few weeks ago thanks to a few topics here.
I know what you mean by it turning into a chilton manual; BUT I don't see anything wrong with that and I value the information I receive and find on here. There are still plenty of other topics that aren't maintenance related.
