What rims are these ? Meed the Studs
imjustdave
Bonney Lake WA
Hello there.
I am trying to find the Studs that clamp "bolt" this rim together. Im also trying to put a name to the truck these would normally be installed on.
FYI the center section was replaced and had a 8 bolt Unimog pattern installed :) so if your counting lug nut holes that won't help you but they were originally 10.
stud info
The stud specs are 3/4" NF thread
the overall length is 2.5
the length under the head is 2.25"
the width of the flat on the head is 1"
the knurl is 1/4" long and at a OD of .81
Thank you to every one
Jones
Sacramento, California
I'm thinking PLS, HEMTT, LVS too-- or some of the later GI semi-trailers with 20" tires.
Maybe this'll help in your search; 1917010 is most likely a part number.
Mfr. 20076 is Titan International Inc., 2701 Spruce Street, Quincey, Ill. 62301
Phone # (217) 221-4302
Mfr. 45152 is Oshkosh Truck, 2307 Oregon Street, Oshkosh, Wisc. 54902
Phone # (920) 235-9151
The studs and nuts (for the HEMTTs at least) are made by Titan and have P/Ns of 03-18930-00 and 52-49524-00 respectively.
Anything else?
imjustdave
Bonney Lake WA
Anything else?
Jones your the man with the info :) Thank you This info is very accurate and helpfull I have what I need on its way :)
David
