What temp should she be runing.
GWP112
wichita falls texas
I have a M998 that keeps kicking the cooling fans or something when temp reaches about 205-210 cools off quickly to about 195 - 200 and the fan noise quits. Driving about 55 mph on hwy and does it every 2 to 3 miles Fluids are ok and no smell of overheating. What do you think it might be ?
sandcobra164
321
Leesburg, GA
NORMAL :driver: I drive them all the time and they do this new from the factory when running down the road at those speeds. If it bothers your, you can disconnect the 4 wire connector by the windshield wiper reservoir and your fan clutch will be engaged all the time and the loud roaring from the fan will be constant. Alot of the problem is how far the radiator is laid back. The air is not very inclined to go through the fins since they are perpendicular to the radiator but as mounted, at about a 45 degree angle to the airflow. It needs the fan to run to draw the air across it.
Augi
42
SF Bay Area
Take a look for bent fins on the oil cooler or radiator. When I got my truck it did this when I drove 50mph. The oil cooler looked like someone had sat on it when working on the truck because 50% of the fins were bent over blocking the air flow. I spent four hours with a flat head screw driver straightening them all and now the fan never comes on. Temps run from 160 to 190 depending on the weather.
Augi
GWP112
wichita falls texas
Thanks to all. I'll check the fins and if that all it must be a come out noise....Drive it till it comes out. lol ill keep an eye on it. Once again Thanks[thumbzup]
