what would cause a injection pump to just quit?
84cucv1ton
New Jersey
i know the pump is on the way out, but it did start and move as long as the rpm was up. now been a few weeks since it been moved. will not idle at all. i was just curies. thanks
3dubs
Houston, TX
Ultra Low Sulfur Diesel (ULSD) it kills IP's and injectors. The sulfur was a lubricant so you have to add a lubricant untill they make an IP and injector to use ULSD in a 6.2. If that is the problem get new injectors too. If you have been adding a lube then how old is it? When the seals go it goes quick.
