where can i find break parts
jgiangiacomo
topton Pa
i have what i think is a 1943 dodge Ambulance. and what i need is all the ruber for my breaks metal is still i rebuildable condition. where and a get wheel cylinder and master cylinder kits as well as new ruber flex break lines ?
A
A/C Cages
Guest
We had one here at my shop last year. We actually found all are (brake) parts thru NAPA.
It was matched up to a typical 1 ton Dodge series truck.
hndrsonj
Senior Chief/Moderator
374
Cheyenne, WY
If not thru NAPA, check with Midwest Military or VintagePowerWagons, both have great websites.
I was just getting ready to type the same 2 sources. Between the two, you will find everything you need for it.
Rthomas
Jena,La
If you can find the part new or nos they should be better than rebuilding the part. I have heard that the cast pits bad and you can never get a good seal again
A
A/C Cages
Guest
We got lucky with ours. It was only the rubber seals that went bad on them and NAPA had them in stock just down the street from us.
WolfWalking
Arlington, WA
One solution to master cylinders that I became aware of is having your original master cylinder sleeved. I have found two places that will sleeve it with a stainless steel sleeve, for the price of a newer complete MS. If you want to retain the original look, and have a MS that will last lots longer with no pitting, check into having it sleeved.
BrakeCylinder.com--Cylinder Sleeving Prices
Here's one, do a google for more.
:beer:
