corelokt
- 2
- 16
- Duffield, VA. (East of nowhere).
just trying to plumb in an aux. oil cooler for a heavy towing job. I can't find an set of the fittings to screw into the radiator.
Do you need any of the alum line or just the male fitting on th end?It is the fittings into the radiator I need.
I knew I had a couple lines that were cut but unfortunately the end you needed is gone.....sorryThe engine oil line. I need some aluminum to attach onto. More is better, of course.
