Which antifreeze/coolant?????
custm86
Kenosha, wisconsin
I'm completely new to this hobby so please be patient guys!!!! I've always had gas engines.
I just purchased a great M1009 6.2L
I'm about to install a lower radiator hose heater.
What is the recommended antifreeze/coolant to replace and what is the capacity?
Thanks in advance.
And yes i searched.
JDToumanian
14
Phelan, CA
Anything will work, but I like to use the kind for heavy duty diesel engines. I use Chevron's DELO Extended Life Coolant for all my diesel powered vehicles. Capacity is 25 quarts. All the CUCV manuals are available for download here on Steel Soldiers.... Did you get them yet?
Jon
rnd-motorsports
Evart,Michigan
As stated above any will work peak or prestone or chevron. just make sure the mix is okay your in illinios so like me in michigan you will need it correct so you dont freeze.:driver:
