Who rebuilds M35A2 Injector Pumps
Mark3395
Geneseo Illinois
Tried flushing the IP of one of my deuces and couldn't get it to work. Pen in the center of the head bounced up and down and liquid was in the sockets of the injector line holes.
I couldn't be lucky enough that it would be easy to repair s spring or other simple component to get it working.
Have it pulled out, and now need a good IP repairman. Anybody have recommendations? Just as well get a couple rebuilt.
Mark
gimpyrobb
dumpsterlandingfromorbit!
27,787
772
Cincy Ohio
Mark, there are a couple other things that can go wrong. One is the "button" that is attached to the bottom of the piston can come off. Its a pain but if you pull the HH you will be able to see if that has happened.
Mark3395
Geneseo Illinois
Thanks guys.
I'll reopen the manual for the IP if I can find it Gimpyrobb. Might give a good clue. Got good help in Illinois that might be able to work with me.
Mark
lavarok
33
Fellsmere, FL
I would think any good diesel shop that works on injectors, pumps, and turbos could do the job. I know Accurate Diesel in Orlando can, not sure about a shop in your area. I posted a copy of their business card in another thread if you want to contact them.
jeepin
12
Vermont
TM 9-2910-226-34 DIRECT SUPPORT AND GENERAL SUPPORT
MAINTENANCE MANUAL
(INCLUDING REPAIR PARTS AND SPECIAL TOOLS LISTS)
FOR
PUMP, FUEL, METERING AND DISTRIBUTING,
ASSEMBLY 2910-178-1185, 2910-759-5410,
2910-908-6320, 2910-968-6317
I think its on the site if not PM me and I can send you a copy. ( I also have the 34P if you need it)
What is the TM for the Injector Pump?
wheelspinner
1,538
North Carolina - FINALLY !
MAINTENANCE MANUAL
FOR
Tried to download this one on the IP but it errors everytime. Can you still send it? wheelspinner@hotmail.com
1,187
I just sent it to you via email.
1,187
Maybe.
Maybe someone else on the site could try to open the TM on here and let you know if they have an issue too.
It worked for me(and I have it saved on my computer).
Diecorpse
Grand Island, Nebraska
You could look up D and D Equipment in Big Rapids MI. Talk to David. He worked on my truck and is reasonable. He has worked on many multi fuels before so he knows his stuff. I'm sure he will tell you exactly what your issue is and how to fix it or give you a good estimate over the phone. He always called me, told me the problem, how much it will cost and ask me if I want it done. He gets things done quick too. Very dependable and quality work. - Todd
