Will not start
Kenneth Cole
44
Wapiti Wyoming
Hi
OK here goes. Last week If she sat for a day or two I would have to turn her over several times before she would start then she would be fine the rest of the day. Not knowing The cause I changed the fuel filter. Anyway then she wouldn't start at all. Found that I wasn't getting fuel up to the filter. I'm getting fuel to the pump but nothing out. So I put in a new fuel pump. I'm getting fuel now but she still will turn over but not start. She blows smoke out the exhaust.
So I'm lost right now. Any thoughts.
Ken
Coug
4,589
Olympia/WA
Blows smoke while cranking but not starting is usually a glow plug issue.
Kenneth Cole
44
Wapiti Wyoming
Hi
I went out after a couple hours and she started up. She sputtered a bit then killed but started up again and she is running fine. I think maybe she just needed to get fuel back through out the system.
Ken
Coug
4,589
Olympia/WA
Hi
Ken
could have stll had air in the system.
DREDnot
447
Phoenix, AZ
Had a similar issue on a 1025A2.
replaced fuel pump because of a broken diaphragm lifter button.
Now getting fuel pumping out of the filter housing...cool.
Hook the hose back up to the filter and it just cranks away.
Cracked an injector line and no joy.
Removed the supply hose from the injector pump snout to give it a crank to verify a fuel pulse there and it fired instantly on the first revolution.... with the hose disconnected!
hooked it back up and it ran fine.
So it seems that you can get an air lock in that section of hose.
So anyone having this baffling problem, try removing the supply hose from the Injector Pump and crank it to clear the blockage.
