Windows tracking
IMA944T
OKLAHOMA CITY
Have drivers window that leans to outside at top and then slightly forward.
Would like to know how to adjust this out of it. The top rear of window is about 1'" from the window rubber. Looked up inside and didn't really see anything to adjust angle. Lubed it good and at least it rolls up and down easy.
topo
282
farmington NM
If the tracking chanel is bad you can check with Steel rubber products on line they sale weather stripping and rubber moldings for restoring vehicles .
topo
282
farmington NM
Im not sure . the channel should hold the window firm and keep is quite . I replaced it in my truck a few years ago and the window moves very little from side to side .
stumps
12
Maryland
I haven't looked at my deuce yet (the recovery is about to happen soon!), but every car or truck I have looked at thus far, has a set of adjustments that move the bottom of the track (inside of the door), in or out, and forward, or back. Surely the deuce has the same?
Sometimes the adjustment is a threaded rod, with a nut that moves the bottom of the track along the rod, other times it is a bracket with a slot, that does the same thing (only less easily)... and occasionally, there is simply a piece that adjusts by bending.
My new deuce has the same problem, so after she comes home, I will be addressing the problem. I would bet on the bracket with a slot.
-Chuck
GoHot229
I have exactly the same thing with mine. I pulled the oval and looked inside. All appears intact and un-damaged/bent, mabe some fiddeling with it?? You have the Hard-top? thats what I have, mabe its not as evident on the Soft-tops
