windshield frames
maddawg308
816
Appomattox, VA
Inner windshields or outer? Both are available used from many sources, including other Steel Soldiers. I have seen new inner windshields, but they run $150 ea.
neilhendrix
Reidsville N.C.
Thanks Mike. New at this I didn`t know there was an inner & outer. I need the frames ,both sides for whats in the pic. Educate me please.
Thanks Neil
rgregj
Spartanburg, SC
There is a guy in Rowan County that has repros for 125.00 I think. Let me see if I can find his name. He's on ebay alot selling MV stuff
devilman96
17
Boca Raton, FL
Buy new ones... Cut the over hanging rubber gasket from around the glass, tape a 1/4 gap and fill the edge where the rubber was removed with windshield sealant (note: this is not a time to substute with silicone)... This will keep your new frames from rotting away!
Also, im running a 10% off special this month on 100$ or more, just enter cupon code CPUQGE in your cart and it will automaticly knock it off the total...
rchalmers3
30
Irmo, South Carolina
Thread revival warning!!!
Hi,
I'm looking for a pair of good used inner windshield frames, (#9 in the exploded view above) sent to MA 02738. My glass is good and I'm willing to take just the metal if you have them available.
Wadda ya got and waddy ya want for them?
Rick
emr
25
landing , new jersey
I have the 3 pcs, the legs/sides and bottom piece,Brand spankin new... usually what goes bad for 65 bucks, it shows in the view above that they come apart, and they do, I have em with the handle on em for 90 I have the outside rubbers with the deal also,...also brandy new... in northern NJ, Randy randyemr@aol.com or 973 219 4499
dabtl
Denton, Texas
HI While sanding on the deuce I found my windshield frames are in pretty bad shape .Does anyone know of a place to get new or good used ones
Thanks Neil
I am not sure your frames look so bad. Unless they are rusted, the rubber will need to be replaced only. If you need glass, the local glass shop can handle that.
