Winter biodiesel and WVO use - what works for you?
Adamlee
Alexandria, VA
I wanted to get some feedback about the successes people have had with fuel choices other than straight diesel in cold weather.
Also, Bjorn, how do you alter your fuel blend in the winter? How much do you use your straight veggie tank (heated) in winter?
If people are running bio blends and veggie oils, and your vehicle has been sitting in the cold for some time, what process do you go through to "wake them up" and get the fuel flowing?
Enjoy the weather! :)
Adam
cranetruck
92
Meadows of Dan, Virginia
Adam, with a two-tank (one heated) system the weather is not a factor.
I start and stop on regular diesel, perhaps with kerosene mixed in. After 15-20 minutes, the second tank, which contains biodiesel/veggie oil is warmed to room temp and I simply switch over to that tank.
Before shutting down, I switch over to the tank with regular diesel so that all filters and the IP end up with diesel only.
Currently, I'm not using the deuce much, I have way to much maintenance work to do, which IS weather related.
I have also started to work on the 8x8, which will feature a heated primary filter as well.
ShepherdAndrea
Dewy Rose, GA
Diesel Heater Questions
My husband and I bought a military diesel heater to heat our approx. 5600 sqft home to cut down on heating costs as we have 5 children and he has been laid off work.
The thing us using a gallon an hour -- is this normal. What can we do to make it more effiicient. Also, the bell keeps going off periodically even when it still has fuel and the heater won't run, only the blower.
Can someone help? It's supposed to be bitter cold for the next couple weeks and we can't afford $60 a day to heat.
Thanks in advance for any help.
ShepherdAndrea, in Dewy Rose, GA USA
Katahdin
24
Scarborough, ME
Sorry, I don't know anything about military diesel heaters, but diesel is road taxed fuel. Use #2 Home Heating Oil if you can get it from a fuel dealer in Georgia, its the same thing but cheaper.
