wood stain as a fuel
maddawg308
793
Appomattox, VA
The local building thrift store has gallons of wood stain in various shades for 50 cents to $1 a gallon. I know wood stain and other wood prep products are flammable, I was wondering, besides the obvious staining of the fuel filters, is there anything against using wood stain as a fuel in the deuce? Probably a dumb question....but I'm taking a gamble here.
1,187
Are you related to WM? :confused:
hndrsonj
Senior Chief/Moderator
365
Cheyenne, WY
I guess when that crap starts to dry in the tank you could always dump some lacquer thinner in the there to loosen it up.[thumbzup]
wreckerman893
Possum Connoisseur
15,644
2,127
You two biiiiite me.
You try one little experiment with laquer thinner and you get a bad rep.
If you put enough WMO in it it works fine.
Ref the stain question.....if you can filter the solids out what is left should be fuel grade....that being said I would only use it after I was out of WMO, waste veggie oil, stale diesel, stale gasoline and anything else I have stashed away for an emergency.
