XM816 Gets To Work
Desert Deuce
17
Chino Valley, AZ
Pulled the XM816 out today to remove the dump bed off the back of my M52A2 and turn it back into a tractor. Everything went as planned, no surprises.
It was a good day!
JAYHAWK 1962
tijeras, nm
congrats!! isn't it nice to finish a job without any bs to get in the way. doesn't happen very often so we should appreciate/enjoy it when it does. i know i do. how many times has that 15 minute job turned into a 5 hour fiasco? btw nice wrecker!
brianrbull
9
Casnovia Michigan
Kevin, good looking wrecker , Nice paint job, I am jealous when they did my paint job they blasted my boom but didnt paint it :(
Any Idea what that bed weighs? I have an S-280 that I want to load into one og my M35's but I am scared of bending the boom.
Also is that you rPioneer equipment mounted by the cupola?
gimpyrobb
dumpsterlandingfromorbit!
27,787
773
Cincy Ohio
Brian, is the s280 full of lead? I have removed and installed them with no problem. They were close to empty though.
brianrbull
9
Casnovia Michigan
The Shelter is basicaly empty other than 2 18k a/c's I guess I am just paranoid . When I go home on leave I will play with it I guess. any guess what the "Real" limit is with the boom fully extended?
Stretch44875
Super Jr. Moderator
31
Tiro, Ohio
My boom will tip the truck before anything breaks. But my truck is a M108 and weighs a lot less.
Desert Deuce
17
Chino Valley, AZ
Thanks for the comments.
Yes, happines is a day relatively free of trouble. It also helps to have competent freinds around.
The pioneer rack was in that position when I bought the truck. As Tim mentioned, I've seen many in this position as well.
The dump was fab'd from military and civi parts. You can't see it but the ram is under there as well. It was built by a previous owner.
Weight of the bed? Don't know. Well below the limit with the boom extended though.
