Zinc and phosporous in WMO?
TexAndy
Bee County, Texas
I've been told that running WMO in a deuce isn't the best thing for the injectors due to the zinc and phosphorous found in motor oil that won't burn up.
How bad of a problem is this? Is there a way to mitigate this problem? Say, only run WMO/Gas mixture in every other tank and run the diesel tank with an injector cleaner?
Edumucate me, please.
stampy
22
Henderson. NC
I don't know about zinc or phosphorous but a centrifuge will remove all heavies down to about .5 micron sooo, I would expect it to catch metals too. I have run some WMO but typically run WVO:grin:
WillWagner
3,073
Monrovia, Ca.
Zinc and phosphorus have been added to lube oil for a long time. Before there were valve seals on modern diesel engines,
oil was drawn past the guides and burned. That is what some of the PM that comes out the tail pipe was and one of
the reasons for using specially formulated oils in new engines so the DPF system won't plug as fast. There were also systems
on engines that took lube oil out of the oil pan, replenished it with clean oil from a reservoir on the truck and injected it into the fuel supply so it could be burned. Cummins used this system on non Ca. fleets up to around 2002 or so until the PM laws made it so the burning of WMO illegal just for the PM it puts out. The required fuel filter for the N14 and M11 engines was a 10 micron just before the fuel went into the system. There were no higher failure rates on these engines as compared to non CENTINIAL systems
when it came to inector failures.
So, if I had access to normal oil change oil instead of failed engine oil, i'd filter it and use it. The oil additives won't hurt the injectiors or pump.
TexAndy
Bee County, Texas
I think the problem with that is that the zinc and phosphorous is in solution in the WMO. Not merely physically mixed. So a centrifuge won't separate them.
