Skinny
- 486
- 83
- Portsmouth, NH
Call me old fashioned but I like a manual pumpCaught me in the funny bone as well. If there was ever a good place to use that line is was right there...
Bazinga!
Once primed, a CP3 pump can sustain itself. But the roosamaster pump really needs a lift pump to function. Timing is also controlled by the internal case pressure of the fuel.I like the set up my duramax has with the primer pump and bleeder! Changing filters is easy!!
The individual who invented the db2 style pump the cucv uses. Now manufactured by stadyne.Whats a roosemaster pump?
Far out i did not know that!!The individual who invented the db2 style pump the cucv uses. Now manufactured by stadyne.
Off topic, but relevant....Far out i did not know that!!
Or eliminate the setup completely....So the lesson here may be to purchase a pushrod at the same time one buys a pump. Better to have your bases covered, yes?
That would make too much sense.Or eliminate the setup completely....
