dstang97
- 33
- 48
- Clover, SC
Ok a little info for you guys. I needed a new engine and cab wiring harness for my m1028 because PO owner hacked it up. This is the 2nd time I have done this swap. The new/used harness is complete and not hacked. I also took out my steering column and replaced it with a known good one, because the old one had a bad wiper switch. No problem i have done them in the past. Here is where it does not make sense. All of my fusible links look fine and tested them with a light. I have good fuses, and cleaned the grounds and fuse box, I can only get the dash lights to work. Any suggestions? So power is not getting to keyed sources.
