Hoefler
- 21
- 38
- White Bear Lake,MN
I need help to solve fuel leak issue. Beneath the fuel filter-and to the side there is a jumble of piping that terminates to an electrical sensor (two wire). Fuel is dripping-slow drip off the bottom of this sensor. There is a lot of fittings: Senso is at end, pipes to a 45 degree pipe elbow, which pipes to a short nipple which pipes to a dual compressuin or flared fitting which connects to long straight nipple. Hard to tell which fitting is leaking. Question-what is this sensors function, why are there so many fittings between it and first long nipple. If I simply take apart and silicone tape the threads, will I need to bleed fuel systyem?
Has anybody else had a leak here?
Thanks in advance.
Pete
I could supply a photo if needs more clarity.
Thanks in advance.
Pete
