Rocwell W/CTIS
sermis
17
Temple, TX
I found a rockwell axel at a salvage wholsale company. It is used but in a wooden crate. Has a rebuild service tag but did not get the info from it. Too dark for PIC's in the wearhouse. It looks like a deuce axel. Has 6 lug pattern. It also has a CTIS inflation system. What would the axel have been on?
They want $200 for it.
40grit
bryan,tx
CTIS alone should be worth more than $200.
worth way more than $200 if it's a front...
get it and sell it like mudlord says if you don't need it...
bottleworks
Central NC
emmado22 said:
There is no CTIS kit, nor dual brake kit. They are factory installed stuff only.
Both systems came on the M35A3. It's my understanding that A3's are rebuilds of A2's, not a factory produced product.
emmado22
158
Mid Hudson Valley NY
There is no "add on kit" you can requistion and add CTIS or dual brakes to a M35A2..
Where do you think they rebuilt the A2's into A3's? AMG's factory.
M1075
Oklahoma City
It might be worth $200 if someone has an A3 and needs CTIS parts. Since they are few and far between in private hands, it might be a risky proposition. Rear axles are usually pretty cheap.
wbdodgeiv
Roanoke, VA
Having never looked at the CTIS system up close, can take off parts be used to put CTIS on a normal A2? I would like to get air to the wheels not to inflate the tires but to shift an unlocker.
flyxpl
10
Chatham IL
It would be much more simple to just tap into the existing air on the truck and use a switch and a seliniod to activate a locker .
wehring
32
Angleton, TX
I have one...
I have an m35a3 axle with ctis for sale. Check the sale section for "wehrings red ass sale"
it came off of an exc cond a3 that I bobbed.
Justin wehrings
979 997 3112
trukhead
dane/wi
That rear axle...
I oculd use that rear axle. I was going to install rockwells under a m1008 and to get the rear and wheels and ctis I was going to buy and bob an m35a3 and swipe the spare wheel from my m35a3 and the bob spare wheel. so ....
:jumpin: aua:hammer:
