Bolkbich
- 8
- 18
- MAHWAH, NJ
My M932a2 was doing funny things. The air compressor was cycling ,the safety blow off valve on top of the air dryer was popping off with only 100-120lbs of air. I started at the dryer and was going through everything when i came across a check valve inbetween the dryer and the first air tank. It was rusted solid and only letting small amounts of air through. I split the valve cleaned out the rust and freed the rubber check. Fixed all my problems. I checked my other 2 m939's that showed no symptoms and they were rusted solid too. One i could free up , the other broke trying to get it apart. They build air much faster now. Just a heads up , if all 3 of mine were stuck im sure its a common problem.
