clutzer
- 0
- 6
- Cambridge/MA
This topic is meant to chronicle my purchase of a M1101 trailer from GovLiquidation.com. I've created this thread in order to document all of the things that need to be done when purchasing an auctioned trailer.
At a high level, a prospective buyer needs to go through the following ten steps.
Useful Links:
Pick-up Day / Inspection
I've compiled a list of things to do when inspecting your trailer to make sure everything is in working order, and more importantly that your ride home with the trailer with be safe. I'll be happy to incorporate other's suggestions into this list, so please let me know!
With the trailer NOT hooked up to the tow vehicle:
Hook up the trailer to the tow vehicle:
Mini road-test:
1 mile check-up (this is VERY IMPORTANT):
The remainder of this topic details my personal timeline. Stay tuned for updates.
2012-02-10
2012-02-16
I've attached some pictures of the trailer I bid on (these are GL pictures).
2012-02-17
2012-02-21
2012-02-23
2012-03-13
2012-03-22
2012-04-02
Got my trailer! Picked it up at JBLM. Joyce was nice and a dude in a forklift lifted the trailer up and dropped it on my pintle. There were moments of nervousness as I hooked up the nonsensically large wire hook-up to my adapter. But it worked. The markers were bright enough and the tail lights worked.
2012-04-02
Put the bow and tarp kit on. What a hellish job: self-tapping screws through metal. Anyway, this pretty much marks the completion of this post. I hope others find this useful: I know the whole purchase and acquisition from GovLiquidation was a big mystery to me. But, it was very easy and everything went smoothly.
Good luck with your own GL purchase!
- Create an account on Government Surplus Auctions at Government Liquidation.
- Start searching for the type of trailer you are interested in: M101, M1101, M1102, etc. Set up automatic search agents to notify you of when a search that meets your criteria is available.
- Once you find something you're interested in, examine the pictures of the trailer and if possible make an appointment to inspect the trailer in person. Then Google around to gather data and make a decision on how much you want to pay for it.
- Try to find a technical manual for the trailer to understand its electrical and breaking system. You want to make sure your vehicle is capable of towing it off base, and you really want to be prepared when you go pick it up.
- If all signs are a go, add the auction item to your Watch List. This is a matter of style, but I don't see a point in bidding early, so I wait until the last day before I bid. I'm sure others have differing opinions on bidding tactics.
- Do your best to win the bid, but don't get into an impulsive bidding war. Wise folks have said after you figure out your price limit in step 3, place that bid and don't look back (set it and forget it). If you win great, if you don't oh well. Oh, and it's important to note that GovLiquidation.com will incrementally bid the minimal amount while not exceeding your upper limit.
- Wait. If don't win, keep trying. If your bid is the highest, it should be a decent indication that you've won the lot. Note however that for my M1101 I had the highest bid, but did not receive an email so to having won the lot by the time they said they would send it (12AM the next morning).
- Get your EUC in pronto.
- Request an SF97. Even if your state doesn't need one, get it. This way if you ever sell it you'll have it--I've read posts from people who have bought a trailer that didn't have an original SF97 and they had issues. (This point may need correcting over time.)
- Wait for your EUC to clear and go get your stuff!
Useful Links:
- rogerm101a2's adapter harness to hook up your 24V trailer to your 12V tow vehicle: military trailer adapter harness M101A1,A2A3 M1101 M105 | eBay
- Erik's adapter harness to hook up your 24V trailer to your 12V tow vehicle: Military Trailer Adapter Cable (Military Trailer on a Civilian Vehicle), X-6034
- emmado22 method for creating your own harness: http://www.steelsoldiers.com/trailers/31824-civy-truck-mil-trailer-wiring-info.html
- 12V/24V Grote tail light: Grote Industries: Product #82212 - Red, Desert Tan, NEW
- 12V/24V Truck-lite tail light: Truck-Lite - Catalog Product : Rear LED Composite Lamps
- First and foremost, familiarize yourself with the Technical Manual for your trailer. I've attached the M1101/M1102 manual to this post.
- Try to determine why the trailer was auctioned. I think it goes without saying that there must be something wrong with it otherwise the DoD wouldn't be dumping it. If yours is in perfect shape, then congratulations! If there is damage, then assess it.
- Verify operation of the Front Support Leg: crank it up and down; make sure it stays locked and secure in the vertical position
- Verify you can move the trailer by hand: with the Front Support Leg in the vertical position and the Handbrake Levers in the upright position, verify you can push the trailer around by hand. (It may be difficult on a gravel GL lot.)
- Verify operation of the both Handbrake Levers: with the Front Support Leg in the vertical position, verify the left brake locks the left wheel when you attempt to push it around by hand. Do the same for the right.
- Verify Tailgate operation
- Verify brake fluid: carefully open up the brake fluid reservoir and verify there is fluid in there
- Verify operation of the Front Support Leg: place it in the horizontal position and verify that it stays there locked and secure
- Verify marker lights: turn on the tow vehicles marker lights and verify they are illuminated on the trailer
- Verify brake lights: depress the brake on the tow vehicle and verify the brake lights illuminate on the trailer
- Verify surge brakes: with a friend beside the tow vehicle and trailer, drive forward and hit the brakes rather firmly. The goal is to have the observer notice whether or not the hydraulic brake actuator assembly moves and actuates the brakes on the trailer.
Mini road-test:
- Tow the trailer 5-10 meters with either yourself or a friend watching the wheels rotating, and general movement of the trailer
- Tow the trailer for 1 mile or so. Pull over and put your hands on the center of the wheel (hub). If it is very hot, i.e. burns after touching it for 5 seconds or so, then you need to troubleshoot the problem. It could either be a bearing issue or brake-drag. I had this due to my Handbrake Levers being slightly bent and causing drag!!
- The wheel/hub should be ambient temperature plus about 20F. If that's the case for you, then congrats: you don't have a bearing or brake-drag problem!
2012-02-10
- Found a prospective batch of M1101 trailers at Joint Base Lewis-McChord, Washington. The trailers are manufactured by Silver Eagle in 2009 and are tan in color. They look to be in really good shape.
- All the 2009 trailers don't have tops to them, so I'll have to eBay one if I win
- The trailers require a pintle hitch so I need to start researching where to get one for a Hummer H1
2012-02-16
- Placed bid on M1101 trailer on GL
- Was immediately outbid by someone else's upper limit bid
- Re-bid
- I did all this with 5 minutes to spare in the auction. I don't recommend this because the auction gets automatically extended by 15 minutes to allow the previous high-bidder a chance to out bid you. And thus begins the bidding war. I recommend placing your first bid 15 minutes before the auction ends. Give yourself some time because you have to enter in a lot of form data when making the bid.
- Sat for 15 minutes holding my breath to see if I got out-bid. Fortunately I didn't and the auction closed with my bid being the highest.
- The GL web site says it will notify the auction winner by 12AM EST 2012-02-17 (that's the following morning)
- I went back and examined the lot description and noticed the Condition Code F7: Unserviceable - reparable
Economically reparable material which requires repair, overhaul, or reconditioning. Includes reparable items. - Panic sets in because of the F7. Google alleviates the panic. Several replies on this site seem to suggest that F7s are usually just fine.
2012-02-17
- As of 1:13AM EST as I create this forum topic, still no email notification from GL.
- There ears must have been burning because I just got my winning notification email at 1:24AM EST.
Dear Valued Customer:
Thank you for your participation in our most recent Government
Liquidation Sales Event. Please note you were the successful
bidder of the lots listed below. Pending payment-in-full, your
official invoice will be posted online under the "Invoices" tab
on the "My Account" page. - Immediately off to eBay to buy the top for it.
- Received an email from GL saying a EUC must be submitted. I'll fill that in and submit it ASAP.
2012-02-21
- EUC submitted as of last night at 10PM. Awaiting confirmation they received and processed it.
- Bought a wiring harness to hook up the 24V trailer to my 12V H1 from military trailer adapter harness M101A1,A2A3 M1101 M105 | eBay
- Bad news on the lighting front: the tail lights should work with a 12V tow vehicle, but be dim. However Mike from Silver Eagle thinks the marker lights are not dual volt LEDs, and therefore will not work at all. Others on the 'Net say the markers will work but be dim like the tail lights.
If you have 24V LED tail lights, and they are dim when hooked up to your 12V vehicle, then for safety's sake you should upgrade them to 12V/24V lights.
Grote offers a replacement light:
and so does Truck-lite:
2012-02-23
- EUC returned to me requiring revisions. Turned it around ASAP and sent it back.
- Struggling with finding a swiveling pintle set up. It seems like only rigid pintles are practically possible with standard hitch adapter plates. Therefore I'm going to have to pony up for the $$$ AM General specific one for the H1: HITCH, PINTLE
- Why a swiveling pintle? Well this trailer will come off-road with me at some point.
- As of 17:48 EST, my EUC status is: "EUC sent to Battle Creek". Now it's in the hands of the government--next update in 30 days probably
2012-03-13
- EUC approved. 19 day turn-around time if my math serves me correctly.
- Getting the H1 trip worthy
2012-03-22
- Spare tires for H1 and trailer: check (fortunately they are one and the same woohoo!)
- Jack kit for H1: check
- CB: check
- Spare front end parts: check
- Tools: check
- Wiring harness: check
2012-04-02
- Wiring adapter: works
- Trailer condition: good
- SF97 applied for: check
2012-04-02
