- 2,088
- 620
- Orlando, FL
I pressure washed the Deuce today and afterwards did an inspection front to back. I look at everything from suspension to drive train, brakes, oil drain plugs , etc
When I was checking the front axle springs and u-bolts I noticed the lock washers on the spring u-bolts did not look fully compressed. I'd looked at them before and thought they were OK. Today I put a wrench on the nuts and was able to turn them. That's not good I'm thinking. Granted, it's a big end wrench for a 1-1/16" nut, but still...
My previous experience with spring u-bolts is you put a 3 or 4 foot pipe on your breaker bar and tighten that puppy down. Then go back after driving the truck a few days and do it again. There's no way I should be able to move it with an end wrench. Anyway, I go and check the TM and I find the torque spec is 170 to 180 FT-LBS. I'm kind of surprised it's that low, so I go put the pipe away and get out the torque wrench and tighten them all up.
All 4 u-bolts on the front axle took about one revolution of each nut to tighten. I have never seen spring u-bolts come loose before so I guess at some point the front axle or springs were changed and not properly torqued.
