Compatible transmissions for the M35a3 with the cat 3116
748
Woodstock, GA
6.71 are the stock ratios.
That should translate into a 37% increase in speed. So, 50mph x 1.37 = 68.5mph. Larger tires should then get me another 15%. 68.5mph x 1.15 = 78.8mph. This also means that I would be able to cruise around 65mph with the engine only hitting about 2,200 rpm.
I wonder how bad the acceleration would suffer though.
jaymcb
not to mention that it's $3600.00 plus labor - and that it probably won't get out of it's own way, especially if you've up-sized to 395's on your A3.
I like my A3, but again, increasing my cost basis on my deuce by over 4k is just :cookoo:
748
Woodstock, GA
I am going to wait until mine is bobbed before I perform upgrades for top speed improvement. Only having to do two axles means that I am only out $2,400. I will provide my own labor. Not sure about the "get out of it's own way" comment but if you mean that it will have poor acceleration, I have several thoughts on that. Bobbed my truck should weight about 3,000+ lbs less so there will be considerably less mass to accelerate. Additionally, the Cat 3116 is capable of generating much more horsepower than the 175 it runs in the A3's, so the engine could be turned up if acceleration suffered too much.
Thoughts?
jaymcb
turning up the fuel and reducing your curb weight by ~20% is going to help, as is losing the parasitic loss of turning the second rear axle. (That's simple physics)
I'd also look at manual locking hubs for the front.
jaymcb
That's Erik's from Erik's military surplus, and it is a Mitchell 3000a splitter. Good luck finding one.
It takes a TON of mods to fit, drive shafts, cross member, etc.
Also, that splitter makes the deuce pretty much a road-only truck because of the angle-limitations from the shorter fabricated drive shafts. Lastly, that splitter is rear wheels only.
**I am saying this having traded emails with Erik about those very pictures. Great guy, was responsive and helpful, on top of the parts I've bought.
trukhead
dane/wi
I had a total brain fart in thinking about how to make my A3 go faster and this is what I came up with.
I am going to acquire a nice M920 and to this said truck I am going to:
Replace front axle with super duty rebuilt front steer axle with huge brakes, (no gears type)
eliminate transfer case with a drive shaft
eliminate one drive axle gearset
install a 2.70 rear gear set
send 400 out to PA and have them bump it to 800 ponies
install frame that pivots on fifth wheel for A3 to ride on
on the A3 remove top, troop seats and fold down windshield and exhaust stack when A3 is on the 920.
I'm guessing I can get 110mph out of the A3 when installed on the modified M920
Why use a M920, it's got that kickbutt winch for tilting the bed to horizontal.:driver:
:doghead:
:jumpin::grin:
m-35tom
226
eldersburg maryland
not sure what tire size you are really going to use so i did the math with radius being 21", trans with lockup converter, 4.90 diffs. 2200 rpm would be 56.1 mph, 2500 rpm would be 63.7 mph. still think it would be worth it? i think only if you really want to keep the auto.
with 4.90 rears and 1:1 trans, your final ratio is 4.90, with 3053 and gear set final ratio is 4.64. any way you go tire radius means a lot.
tom
Woodstock, GA
m-35tom,
Is my math wrong?
6.71 / 4.9 = 1.37
Basically a 37% increase in final drive speed from the Ouverson gear set.
On my M35A3 I can run 50mph at 2,700 rpm with the 3116 Cat.
So 50mph x 1.37 = 68.5mph
Tires are about 42" diameter so going from that to a 46" or 49" diameter tire would roughly translate into an additional 15% increase.
So 68.5mph x 1.15 = 78.8mph
trukhead
dane/wi
Circumference = Diameter x PIE (YUM) PIE is actually a funny looking character but I like PIE! Yes I do!!!!!
14.5 x 20 Michelin is 42ish inches in diameter ( I didn't measure one )
PIE = 3.14...... (3.14 for this discussion)
So:
Michelin tire goes 11 feet/rev
11ft x 2200rev x 60minute x 1(gear ratio) x 1 mile
rev.....minute..... 1 hour........4.90............. 5280 ft
a stock 14.5 x20 michelin with a 4.90 gearset at 2200 engine rpms is going about 56 mph
:driver: :hammer:
748
Woodstock, GA
So:
:driver: :hammer:
Yeah, BUT, I am not turning 2,200 rpm. The cat will do 2,700 all day every day.
So... according to your math, if you apply the right rpm:
(56 / 2200) x 2700 = 68.73 mph which is basically the 68.5 that I have shown above.
You really need not even apply pi to figure this out. Given that I know what speed I can travel at what rpm (50 mph @ 2,700 ish), I only need to know the different gear ratios and tire sizes to determine the speed. The pi's and everything else cancel out of the equations.
m-35tom
226
eldersburg maryland
sometimes other methods work, sometimes they give false info. the simple math formula for this is :
mph = ( rpm * radius) / ( 168 * ratio)
using loaded radius is more accurate, ratio is final drive ratio including trans, rears, etc.
tom
