Two Tone Wet Sanding
748
Woodstock, GA
Does anyone know if my colors will run (bleed together) if I try to wet sand where I have two different colors of paint? The attached picture shows the area I want to sand so that it is smoother and cleaner (hopefully) looking.
eagle4g63
34
North/west Indiana
As long as they are enamel paints, they shouldn't bleed or mix with each other.......Also they need to be good and dry. Ive wet sanded many 2 tone single stage paint jobs.
Of course they were also gloss paint.....but I don't think there should be a problem.
If you really want to know......just paint a scrap piece of metal with both paints(just next to each other or in a stencil like you did) and try that piece first.
doghead
4 Star General /Moderator
1,191
Why wetsand at all? It's an MV!
748
Woodstock, GA
Yeah, I already messed it up a little bit. The wet sanding was needed because I had some run marks from the stencils I used. Didn't have to be perfect but it would have bothered me. Also, I plan on using this truck to tail gate at Georgia Tech football games and I want it to look fairly good ("Rumblin Wreck" is a play on the "Ramblin Wreck" from Georgia Tech mascot car (see avatar)) .
I had some places on my doors that I just couldn't get the new paint to blend because the surface was so rough in spots. I wet sanded the doors and hit them with a few coats of flat paint and they looked very uniform in color while still having a rough, flat look. That is what led me to contemplate wet sanding the lettering.
