paraclete comes
- 5
- 18
- southern ca
picked up a 12k 24v warn industrial winch, new.
I am looking to get into gauges soo, got any pics of your setup?Just finished installing the AutoMeter Mini Gauge set. Now I can monitor my temp and oil pressure. Probably gonna try to swap the voltmeter out for something else since I already have the stock voltmeter, but 1.5" gauges aren't common.
My camera's not the best but I will try to get some shots. It ended up involving a lot of, "why'd I do it like this, when this would be much easier" but I finally got it done.I am looking to get into gauges soo, got any pics of your setup?
Whats your angle? hahaha
Finished spraying mine. I went with ALK-200 instead of rapco paint from the local PPG distributor sprayed over PPG OMNI epoxy primer. Even with a cheap HF HVLP spray gun I only needed a half gallon to cover the entire truck.
I should have grabbed the color code to share. The shop sold me on this stuff because they had the color code they developed for a duece builder out of unionville, IN. Not sure if he's a member on here or not but if so, thanks for letting me piggy back on your paint purchases!
