where do I get a starter for onan 5kw generator
CUCV85
central/ny
I know I know I posted a request in the wrong tread for a starter for a 5kw onan generator. I see 1 listed on ebay that's it! Where you guys getting your used or new parts? starter type II is the newer one listed as 191-1948-01 the old type I is MHP7101T mfr No 191-0828 either one will work. Used new don't care. Type II is the gear reduction upgrade replacement military started using in 1990 and still use it!
doghead
4 Star General /Moderator
1,193
There are 2 in the classifieds section.
Or, Delk's has them.
Munchies
Keesler Air force base/ MS
I will add.... Stick with the Type II like I linked to above. Faster cranking gear reduction... Easier start, faster start, less battery drain....
Easier to install! Weighs less.
cant go wrong really. Maybe pull the old one, rebuild it, put it in the spares box. :beer:
