Santa Brought a Convoy Warning Light Kit
jonesal
Mission Specialist
74
Brookings, SD
Santa was was more generous to me that I deserved and brought this:
I'm going to install it on this:
So the question is, do I leave it green or paint it tan prior to install? Anyone with a tan truck have convoy lights installed? What color is your hardware? I have the paint but I don't think I have the patience to wait...
I'll post install pictures as I go.
Al Jones
'84 M923
jw4x4
Dayton, Ohio
After you install them green, you will likely be removing them and painting them tan. Or you could sell them to me as they would match my green truck and you could find some tan ones that match your truck. All kidding aside, do you know of any more kits out there for sale?
jonesal
Mission Specialist
74
Brookings, SD
Google the NSN off the box and there are several kits out there for sale. The P/N 12301057 will also lead you there.
Al Jones
'84 M923
Stan Leschert
87
North Vancouver, BC, Canada
It won't give you instant gratification, but get out the rattle can, and make them match your truck.
It's way easier than making your truck match them.
If it's worth doing, It's worth doing right .... the First Time!
juanprado
3,201
Metairie/La (N'awlins)
My muffler, tailpipe, one mirror head, and some other parts are "green" but most of the truck is still tan. I like the personality it gives it as you see many trucks on GL with mis matched colored parts.
The top triangle bracket on one of my convoy poles is green.
I also like the idea of a camo cover on a tan truck and a tan cover on a green/camo truck.
Just my .01
Merry Christmas! :)
Artisan
229
CDA Idaho
When I first saw green and tan mixed I didn't like it, but
it has kinda been growing on me ever since I have seen
pics of what appear to be MV's in current use by the
military w/ misss-matched color parts.
In your case I think it would look good. Things will be symetrical...
No matter congrats, WAY Cool that kit is.
DieselBob
15
Arnold Maryland
Great score on the early Christmas present. As mentioned before I think I would leave it green. Many active duty trucks are not all the same color. Kits and updates are added after the last repaint. 2cents
gunboy1656
24
Beaver Falls, PA
Congrats. I would leave them green.
I found a kit on facebook a guy was selling, just have to find out how much it will be for shipping. Not a brand new kit but I am not going to complain about it cost is reasonable.
bikeman
503
Ft. Bragg, NC
I'll guarantee you right now there are trucks sitting in motorpools with mismatched parts, colors, ETC. mirrors, doors, handles, tailgates, hoods, yep... had them all. Had a tan HMMWV with everything tan except the replacement hood which came OD Green. All of the tan stuff was moved from the old hood to the new and it was installed on the truck that way. Seen mismatched canvas, hard and soft doors (not armored), even grill or front pieces for MTVs.
I'm the guy that even if I wanted it to match I'd install it first... enjoy! Merry Christmas!
M35A2-AZ
443
Tonopah, AZ
I just put a set of convoy lights on my M936 and it was not to bad of a install. But the two nuts for the u-bolt on the lower right side are a B((*&^^.
The battery box is in the way and the foam does not help.
jonesal
Mission Specialist
74
Brookings, SD
Any chance you can post pictures? Also, have you put a tape measure on the lowered height? I'm getting nervous that they might be too high for my shop doors. I hope 11 feet is enough.
Thanks for the heads up on the ubolts. I wondered about that.
Also, what's the deal with the directions saying to hook the harness into the dimmer switch? Wire 16A? It does say you need the service drive lights on for the convoy lights to operate - but I haven't pulled out a wiring diagram to figure out the dimmer switch deal? Any comment?
Thanks,
Al Jones
hndrsonj
Senior Chief/Moderator
359
Cheyenne, WY
Yep, I just looked. They are now sold out. They were right around $200. Glad I got mine!
DieselBob
15
Arnold Maryland
I ran a separate power feed through a circuit breaker for mine. Figured if something went wrong I hopefully wouldn't loose all the lights or electrical system. Although mine is on a deuce I would think it would be easy enough to hook up something similar on yours. Just a thought.
M35A2-AZ
443
Tonopah, AZ
Thanks,
Al Jones
I lowered my lights 4" and I will check when I get back home. But I think when I was checking on putting my lights on 11' may not clear.
juanprado
3,201
I did not wire it as the directions show. I took a Y off the circuit breaker on the firewall and added another circuit breaker to the firewall. I then ran the hot wire from the new circuit breaker (auto reset) to one side of the switch and the other side to the 2 lights. This way the lights can be on anytime the power switch is on. It seemed much simpler and better than taping the dimmer switch and the light circuit. Nice big hole next to the pcb box to route wires into the dash.
I also used a bracket from spruce surplus to mount an indicator light. The other switch & light is for a set of front driving lights under the bumper.
The height is going to be tight. I have 11.00 g177 on stock wheels and my set up with the pole in the lowest setting is 128 inch. I have small led strobes instead of the reflector beacons which I think are taller.
Some pictures for reference.
Merry Christmas,
jonesal
Mission Specialist
74
Brookings, SD
Thanks! That helps a lot. I think I'm in trouble with height but I did measure my shop door and it's 11'6". We'll see when I fit everything up. I also see I might have to make some small changes for my soft top.
Thanks again,
Al Jones
