davidkroberts
- 24
- 38
- west tennessee
well i was reading the forum and have never seen the pictures on it posted so thought i would do it and get ya'll to critique it and see if i did it right. I was looking for the "orange wire" on the top of the relay but mine doesnt have it so i left it alone. I left the controller card installed and functional and was using the switch as a backup and to help on warm starts where this one seems to be a bit sluggish. I didnt know that there were two blue wires until i was under the dash.
1. isolated light blue wire on controller card harness (beside purpleish wire) and spliced a wire going to a LED switch.
2. from LED switch Ground terminal ran a seperate wire to a easily accessable ground block. I usually make add-on stuff where i can pull a ground easily if needed.
3. switch is only powered when the key is in the start position not the accessory position, if i was going to do it again i would get a momentary switch but oreilles didnt have any.
4. If i hold it for a slow 10 count it seems to start as if the relay had just cycled
If i did this wrong please tell me i wont get butt hurt or anything. I was trying to follow about 4 different sets of directions on here and some of them were conflicting. I just want this done correctly. Thanks
