valve cover leakage
drlogistics
Lapeer, MI
Does anyone have any suggestions for getting a better seal around the valve cover? I've got a new gasket under there and I've tightened down the acorn nuts as tight as I feel comfortable doing. Any tricks would be appreciated. Thanks in advance.
1,124
Take the cover off and verify that it hasn't been overtightened and bent. Older stuff with thin, stamped steel valve covers are frequently distorted from being overtightened.
You can straighten them with a hammer and dolly.
YkDave
Yellowknife, NT. Canada Eh?
X2 on that, alot of valvecover leaks (regardless of the engine!) are caused by the valvecover being distorted from someone cranking down the bolts trying to stop a leak. If it is warped, some time and patience can fix that.
If all else fails, a bit of gasket sealant should do the trick!
topo
222
farmington NM
I have used the clear silicone on oil pans that where warped . It's thinner and easy to spread a thin coat on each side of the gasket all the way a round .
YkDave
Not a bit of sealer, lots and lots of it. Use black silicone.
Theirs a difference between fixing it right/doing what you have to do, and just saying F'k it and whacking it full of silicone LOL
Unfortunately, for some reason i tend to assume people like to fix things the right way, or at least attempt it before taking the easy way out!
