AMGeneral
- 114
- 63
- Connelly Springs, NC
Well,I have FINALLY gotten around to starting this thread that I had promised I would start on 2 years ago!!
What I intend to cover is the necessary parts to change/replace when doing a powerplant change on a M39 series 5 ton truck,as well as the proper procedure of same.
The object of my personal repower is a 1967 Kaiser/Jeep M51A2 5 ton dump that I aquired from SS member Papabear several years ago in trade for the M553 GOER.
Although my truck is a 5 ton dump,this will cover a powerplant conversion on any common M39 series 5 ton.
First off,you will need a Mack engine and overdrive transmission from another 673 powered 5 ton truck as well as the complete throttle linkage from the same truck,from the link passing through the floor that attaches to the "gas" pedal all the way to the link going to the injection pump.
You will also need the complete air intake piping from the air cleaner to the turbo inlet,all of this is Mack specific.
Also,if it is possible,remove the fuel supply and return lines from the donor truck as well as the main air line from the compressor to the "wet" or lower air tank,these are also specificly curved or made for the Mack powered trucks.
If you are pulling the Mack from the donor truck yourself,notice that the right had frame rail upper flange is cut out to clear the accessory drive on the 673 Mack,measure and make a pattern of this because you will have to do it on the truck that you are repowering as well.
In the following days,I will cover in pictures as well as measurments where to place all the necessary parts.
