What size hone
runk
66
Houston, TX
I used a NAPA service tools 265
"Use to hone drum brake wheel cylinders and disk brake calipers from 3/4" to 2-1/2" (19mm-64mm). "
gringeltaube
Staff Member
2,655
Montevideo/Uruguay
OPTIMAL: not sure...; size: 1-3/8"
You may shop online for: CTA Tools 1146 1-3/8-Inch Brake Cylinder Flex Hone.
G.
ducer
Ober, indiana
Take a wheel cyl. in to NAPA and have them get you a ball type hone. the ball hones make a much nicer crosshatch pattern and are usualy a finer grit. I used to use them at the dealership, they are great.
Rob I dig the new avitar. :popcorn:
Denny
CARNAC
The Envelope Please.
684
Corpus Christi, TX
Ah, there in lies a problem.
Take wheel apart, leave to go to NAPA. NAPA sucks here and I would be told to go on line to order before I get out the entire question/part number (like happened last week). Wait a week for the part.
So while the wheel is apart, wind storm hits, even if covered up, dust gets into everything and now I have more of a problem than I started with. One thing I've learned in the desert, start something, you better be able to close up in a timely manner.
swbradley1
Modertator
1,907
Dayton, OH
How true. I don't like to start anything I can't finish (yes, the exception is my LDT engine swap) because you don't know what will happen. Case in point. Gimpy and I pulled the alternator off my backhoe Friday night with the intenetion of me having it checked and fixed on Monday. Nope. It is a Magneti Marelli A127-55 that they can't fix. Now my backhoe is down blocking the Deuce that I want to get out to sell.
Get the parts before you start so the truck isn't down for days. ;-)
gringeltaube
Staff Member
2,655
Montevideo/Uruguay
Ducer: the tool I suggested above (CTA) is just one of different brands. This IS a flexible, ball type hone, and it IS the correct size 1-3/8" for the M35 wheel cylinders!
Napa possibly carries KD (would be model #2483)
None of these tools should cost more than $30.
G.
CARNAC
684
Corpus Christi, TX
Thanks again and I should have it tomorrow---unless NAPA screws up. The other places were going to have to order it from KD taking 5-7 days.
