5 ton tractor oops
jw4x4
Dayton, Ohio
"He who hesitates is lost". In this case, if he would have kept going instead of stopping, I believe it would not have tipped over. In the moment, freezing up is understandable. I bet it scared the bejesus out of him too.
wreckerman893
Possum Connoisseur
15,647
2,141
You should try loading the Power Unit of an M48 (without the trailer) up a set of ramps onto a stepdeck.
The first time I did it my "O ring" achieved a "Pucker Factor" of 10. You couldn't have driven a straight pin up my butt with a 12 pound sledge hammer.
jw4x4
Dayton, Ohio
The driver HAD a spotter on the ground and another standing on the front of the trailer. Either it was poor communication or the driver was too stuck-up to take the guidance. No teamwork there at all. Amateurs.
cumminsbandit
Lake Mills, WI
Agreed! driver error... it was loaded and hauled there just fine... but couldn't manage to back her strait off? must be how they get experience?
steelandcanvas
88
Southwestern Idaho
Look toward the end of the video, the ground spotters just stand there even after the tractor tipped over, and then slowly walk around behind the tractor, out of view. Something smells real fishy about that video.
73m819
329
gainesville, ga.
That WAS the first and LAST time WM loaded a MK48 FPU (later he did say he was constipated for 3 days)., I did the rest, not sure which is worse, going up the ramp, not knowing if the FPU will try to go over backwards or the break-over on to the trailer and the FPU try to tip forward with the break-over.
bikeman
503
Ft. Bragg, NC
def not american. but that also happened with a Stryker in Kuwait when we were loading them out. the trailers were not wide enough to fully fit the vehicles and a tad of the tires plus a lot of extra stuff, overhung the trailer.
