Spare IP
danjrofpa
Sunbury, Pennsylvania
I am trying to get a spare IP to have on hand. My pump does not have the port closing dimension. stamped on it but does have the button size.I assume that there is no way to match up a spare without both dimensions.If anyone can confirm this I would appreciate it. ( I even checked it with a magnifying glass).
Thanks again
storeman
52
Mathews County, VA
If it has button size, it has PCD. Remove paint around the base of the pump. It is often engraved VERY lightly. Would not show up through paint.
Jerry:driver:
danjrofpa
OK, I cleaned the paint off with a brass wire brush and inspected it with a magnifying glass and there is nothing there. Kind of odd, the button code is stamped pretty deep into the body.Maybe they forgot the PDC.
storeman
52
Mathews County, VA
Okay, no pcd. I assume your pump works okay. A replacement/spare pump with its own specified timing button should be able to be used without issues.
Jerry
RIrvin
Kirkwood MO
Does anyone have a "best practice" procedure to share that is appropriate for storing a spare IP? Since it may be stored for many years before being called into service, how best to keep it from gumming up , drying out or other damage while in storage?
RIrvin
Kirkwood MO
That seems like beneficial steps to limit air / moisture intrusion. Should some type fuel treatment be placed / injected into Spare IP intake prior to storage?
1800 Diesel
25
Santa Rosa County, FL
If you have a safe storage are, I've used large coffee cans to store IPs & oil pumps etc, fully immersed in 15/40 oil. Another method is to vacuum seal the IP after it's been soaked in oil a couple days. To keep oil from being drawn out during the process, you have to double-wrap the item in plastic first & then place it inside the vacuum bag for sealing...
