Dash accessories Problem M931
LtLunatic
Richton, MS
I have dug around in the manuals and on here and have been unable to find the info I need. The problem I am having with my 931 is none of the air powered accessories will work on the dash (they worked fine before). After I run the truck an extended amount of time (an hour or so) they will start working again. and the truck is building up too much air and blowing down. Any help on this issue will be greatly appreciated.
doghead
4 Star General /Moderator
1,192
Look it up, the TM's are searchable.
Search the site too, for more info.
Did you read the whole thread I linked?
doghead
1,192
Here's the replacement part #
277147RX
Suprman
707
Stratford/Connecticut
Replace it they go bad. Fleetpride usually has them Napa never has much anymore. I believe it is a part that should be replaced proactively when you first get the truck.
