5 ton fuel tank on M35A2?
socom688
Florida
Hey guys, I was wondering if either a m939 or m809 fuel tank could be put in the m35a2 without a significant modifications? I was looking for something to increase fuel cap, but didn't want to go through the hassle of a dual tank setup. I have no idea the dimensions or setups of either ton tanks, but I figured this would be the place to ask!
Kloakndagr
On The Road/California
I just swapped out the tool box/step with a 50 gallon step aux tank. It's still a work in progress, the tank is going to be for storage and will utilize a hand pump to pump the 50 gallons into the deuce tank. When completed I'll have 100 gallons of fuel, should be able to get out if California without having to stop, don't wanna look back as the state is being overrun by undesirables aka zombies.
doghead
4 Star General /Moderator
1,170
Neither has provisions for an in tank pump.
73m819
315
gainesville, ga.
You could ues a tank from a 39 series a2, it had a in tank pump (same pump as the deuce), this would give you up to 78 gal. with a single tank.
socom688
Florida
Ok thanks for the input guys. I am having a hard time finding parts source, let alone a fuel tank for an m39 series truck. I will keep an eye out and keep brainstorming this idea.
73m819
315
gainesville, ga.
M39 series is the 5t series before the 809 5t series, also check the dia. of the 809 pickup access, against the deuce tank pump mounting, could be the same or close, if so, you always could drill/tap new mounting holes, what ever you do, replace the STEEL mounting screws with BRASS or STAINLRSS, this will prevent the screws rusting to the tank, then breaking off when you try to remove them and the repair fight.
wreckerman893
Possum Connoisseur
15,616
2,008
Use a duel tank set up with a pump to transfer fuel from the aux tank to the primary. That way you don't have to do a lot of plumbing. Some of the older 5 tons had a similar setup. That way you can use a stock deuce tank and brackets and just mount it on the drivers side of the truck.
doghead
1,170
What truck has an 81 gallon tank?
73m819
315
gainesville, ga.
THE 939A2 has a 81 gal. tank, on The older 5ts, the big tank is 78 gal.
Reckless
Georgia
I have a m54 tank and brackets, just needs a pump! (Same pump as a deuce, just have to slide it down)
Let me know if your interested!
socom688
Florida
Thanks for the offers guys. But I wont be doing this mod for some time,l Im just planning ahead:-(. I don't actually have the truck yet, I am picking it up in a week or so from another member on here. I am just planning ahead. I barely got my old lady to allow me to get it the truck in the first place!:wink:
jrobinson5093
jakin georgia
I don't mean to hijack this but Im wanting to put a M35a2 fuel pump in the tank on my M818. Even if the mounts don't line up it should be easy to adapt. Does any one have a entire pump and sender assembly for sale?
