Transmission leak at shifter shaft
milradioman
Kooskia, Idaho
I have been going through a newly acquired M1009, the transmission was low on fluid, I serviced the transmission with new fluid and filter. I Started and drove it to test for further issues; I notice transmission fluid leaking from what looks like the shifter shaft at the transmission, I am unable to find info in the TM, is there a seal that can be replaced?
Brian
beltfedonly
Wilson/NC
Yes there is a small seal, Napa has a special tool that slips over the shaft and enables you to remove the seal.
