Heating oil vs offroad diesel in MEP802A
kzguy2
Bucks County, PA
Hey guys, new to steel soldiers. I just bought an MEP802a gen set that has 500hrs. Runs and powers great! My question is what are some of the advantages/disadvantages of running heating oil through this unit? My house has a 275gal home heating oil tank that I was thinking ill use to run this. However I have a spare 150gal diesel tank laying around that I could use instead and fill with diesel. Any thoughts? Im worried about hard starts when cold and excessive smoking if I go with the heating oil option. If I fill the 150gal tank how long will the diesel last before it starts spoiling?
thanks!
cuad4u
89
St Matthews, SC
I have two diesel fuel tanks on my farm. One is 300G and one is 600G. Even though I "turn the fuel over" at least once a year, I add a product called "Killem" which is a biocide. Diesel fuel is an organic compound. That means it was once a living organism. Anything that is organic (HC) has many things that either try to eat it or grown in it or both. That is what happens to diesel fuel. Organisms can (do) get into diesel fuel and survive and even thrive and set up a living community that gets bigger and bigger and bigger. The biocide kills the organisms already in the fuel and kills new ones that get into it. Over time the biocide breaks down and has to be replaced. If you do not put a similar product in your diesel fuel "things" (slime) will start growing in it and these "things" will clog filters and generally reek havoc in the fuel system of your generator. Other than that I do not think diesel fuel will lose its BTU content over a reasonable time.
kzguy2
Bucks County, PA
Hmm, second thought I think ill stay away from the biocides then. I dont want to have to worry about toxic fumes around... pljs I love to smell my diesel exhaust! Lol
tstone
17
Westminster/MD
As stated in the link using home heating oil in military diesel gensets , HHO and off road can be different in sulfur content depending on location. My local supplier in PA sells HHO that is still the high sulphur content; the off road is ultra low sulfur. I choose to use the HHO in my gen sets and other off road equipment as it helps to lubricate the old style mechanical injector pumps. The ultra low low sulphur has less lubricating ability and should be supplemented with a lube additive to help reduce wear in the old style I P's. The HHO also has a higher BTU rating and gives better performance under load, however, under extreme cold conditions it will gel faster if not treated with an additive.
Hope this helps.
jatonka
111
Ephratah, New York
For information , in New York State, Home Heating oil is now Ultra low sulphur just like diesel fuel both on and off road. We need lubricity additives in all of it.
Thanks for the info on Biocide additive causing dangerous exhaust emmissions, I didn't know that before. JT
Rapracing
Western Pennsylvania
Hope this helps.
:ditto: Me too
kzguy2
Bucks County, PA
Interesting. Seems HHO is the way to go then. So its ok to run in the newer mep802a units then? Mine is a 2004. I actually just got done pumping out the tank and filling with hho to run some tests. Runs great, but some seem to smoke a little more, especially on start up. Its supposed to go down to 26 degrees here tonight, so im going to try a cold start in the morning and see how she does. Thanks for all of the info! Great forum!
m16ty
227
Dickson,TN
I'd use whatever had the higher sulfur content. The off-road diesel around here is now all ultra low. We don't use HHO around here so I have no idea about that.
kzguy2
Bucks County, PA
Update: So fired her up this morning while 19 degrees out and she started up good.(didnt even use the preheat!) Is it bad to not preheat? I was just curious so I didnt use it. Smokey though!. While running on offroad diesel she seems to start easy and smokes wayyyyy less. I guess thats all the Sulphur and lubricant in hho?
Ratch
Chester County, PA
I ran my 002 in 10's and 20's temps on both hho and on-road diesel, with no difference in performance or smoke at all. There's no place for me to buy off road diesel, so I don't use it.
You sure it's not an illusion? Unless you purged the pumps, lines, and filters, you probably started off whatever it ran on last. The temperature without preheating is probably why it seemed Smokey.
kzguy2
Bucks County, PA
Yea I purged the lines by completely draining tank, then filling with 5gal hho and ran it for 20min yesterday to burn off the rest of the offroad diesel in the system. Im going to swap back to offroad diesel again just to check. I believe it is ultra low sulphur offroad that im using...
Ratch
Chester County, PA
No, but it will supposedly be harder to start. I'm pretty sure the 802 has glow plugs, but I didn't pay much attention when I had mine apart. I'm not a fan of glow plugs.
Engine warming that runs the oil or coolant through a heater before starting is designed to ease startup and prevent running before the oil is thin enough to circulate in extremely cold climates. Preheating is primarily to warm the air entering the cylinders to reduce it's resistance to compression heating.
CDR
new york
HHO is the same thing as diesel. Even if it wasn't I wouldn't worry about it since these generators can run on jp-4 which is 50 gas!
m-35tom
226
eldersburg maryland
one of the many 802's i recently got has a coolant heater. goes from 30° to 180° water temp in under 15 minutes.
