- 6,425
- 4,990
- Ft. Lauderdale, Florida
X2 on this when I first looked at it but I don't have enough knowledge or experience to comment on that.Also, you may want to check in the -20, concerning the return spring placement. I believe that both ends of the return spring are to be hooked into the elongated slot that the anchor pins ride-in.
In your #1 picture, the left-hand of the spring is in a hole above the slot, this makes the spring crooked, and have less return force. It's also riding on the WC.
The only thing that's truly wrong is the spring placement. The adjusters were either turned the wrong way or you turned them farther than they needed to go and they "started over".So I am adjusting, cleaning, checking, repacking bearings and such.
I get to the right front and find minor adjustment screw turns makes zero difference on rear shoe. Open it up to find rear shoe stuck, will not move. I learn a lot on SS with the pictures.
So what is wrong with this picture.
I suspect you're correct but I guess it's possible he was going the correct direction and once he went past the highest spot, the adjuster "fell off" the shoe.You are turning them the wrong way. The way you have them there they are adjusted all the way down, and if they are pushing the shoes out, they won't stay.
You are correct. See image below:Also, you may want to check in the -20, concerning the return spring placement. I believe that both ends of the return spring are to be hooked into the elongated slot that the anchor pins ride-in.
It's definitely thin. I don't remember what the minimum thickness is, but they're .333" thick when they're new.And the shoe on the right look very thin
