acme66
- 8
- 0
- Plains, Montana
I have been at this plate a few times now, once with straight gasket sealer like I found it and like the other axles. Once where I made up a nice thick cork gasket and sealer on both sides. For the life of me I can't find anything wrong, the cover sits flat, no damage to the sealing surfaces... yet I haven't so much as slowed it down. Each time it was like I had made no change. Doing some reading here I will go and pull the vent and check that it is not plugged but it spins freely and springs back so I bet it is fine. I admit I have not waded through the TM, mostly I figured how complicated can this be? It seems to be leaking from the center of the bracket that supports all the air lines or there about. It isn't that big of deal and stops leaking before (but close to) what I would consider the minimum for rear end fluid level but until then it coats the back of the truck and the stairs in oil. Have I missed something or do I just need to have at it one more time. I could make gaskets from thick and thin gasket paper, thick and thin cork and thick heavy rubber or just RTV from the tube.
Ken
Ken
