duecesarewild
- 0
- 1
- crestview, florida
I will start off by apologizing for my awful username, didn't do well with hooked on phonics. Our drop truck, (the one we rig up to drop out of our MC-130E Talon aircraft) hasn't run for 2 years. The lift pump was bad and when it did run it kept blowing out the secondary fuel filter "o"rings. I replaced the lift pump and entire secondary fuel filter assembly. The IP shutoff was completely gummed up and I had to work it free with Brake Clean. I can get it to start and Idle but have to hold down the pedal down to get it to start. Once it is running seems to run pretty good, has power and idles down. If I shut it off it is difficult to start and sometimes have to use ether to get it to run. The truck used to start at a touch of the button. I attempted to bleed the fuel system at the injectors and got fuel and an RPM drop at cylinders but nothing from #2 and #4. It seems to run fine with no miss at idle or WOT and shuts off with the cut off. I removed the IP cut off cover and made sure the lever was moving freely and snapping back to the 7 position. Looking for ideas? I have owned 7 Deuces but sold them all of except for three and all of them have been great in the fuel department. I am located in the panhandle of Florida so heat and crappy fuel are problems. Since this truck is considered an "equipment item" (not supposed to be operable) and not a vehicle, I can't get any support from our Air Force motor pool and most of the kids now only work on LMTV's or MRAP's. Sorry this is so long and thank you for taking the time to read this,
MSgt Rob Hoeft
919 Special Operations Squadron
Duke Field Florida
MSgt Rob Hoeft
Duke Field Florida
