mikey
- 40
- 28
- Lake Como, PA
I have read the TM's and searched the forums, but can't find an answer to my question.
When checking the trans fluid for my M931A2, my truck has OE/HDO 10, I start the engine, let it warm up, put it in neutral with the parking brake on and I check the fluid level. I get the same result every time, picture #1. I am careful to slowly remove the dipstick.
If I immediately shut the engine off and check again, I get picture #2 every time. I'm talking about within 10 seconds of turning the engine off.
According to the TM, I should be adding some trans fluid based on picture #1 with the truck running in neutral. However, I want to be sure I don't overfill it. I'm cautious because the check with the engine running appears to have such little fluid on the dipstick. There is always a very slight amount just on the edge. What you see in picture #1 is what the dipstick shows every time I check it with the engine running. I want to be sure this is normal and correct before I add more fluid. It just seems strange to have such a small amount of oil on only one side of the dipstick.
Thank you!
Mikey
![IMG_2864[1].jpg IMG_2864[1].jpg](https://www.steelsoldiers.com/data/attachments/358/358084-47eb11172d60247982e4a02dbcb84030.jpg)
![IMG_2865[1].jpg IMG_2865[1].jpg](https://www.steelsoldiers.com/data/attachments/358/358085-d03ca5e5b41d0c8282a060a61b818c67.jpg)
Thank you!
Mikey
