tim292stro
- 40
- 48
- S.F. Bay Area/California
...So what's the smart thing to do (about putting away hot food in the refrigerator)?...
Yes, the transition time is the critical part. Also the circulation around the container part that Mike talks about is a reason to look at your fridge and make sure it doesn't look like this:Put it in shallow containers and make sure there is air circulation on all sides. What you are trying to do is get the temp from over 140 F to less than 40 F as quickly as possible (less than 30 minutes, preferably 15-20). The 'danger zone' is considered between 40 and 140 F, where the number of bacteria can double every 20 minutes.
Over-packed refrigerators will never cool the food at the front properly, and with the doors open the food at the front also gets warmed more often. Bad combination. And you need to clean (next to godliness right?) frequently - especially if there has been any rotting food anywhere in the fridge, or leaking meat containers.
View attachment Refrigerator_Myth.pdf
Ideally you want to cook food for serving immediately afterwards, or within 5-10 minutes (max). Any more than that and you need a holding plate, or food warming box to keep it hot (like a RAK-15 if you're mobile...). There is a sweet spot for those too, as holding it at temperature will continue to cook and dry out the food. If you intend to store it pack it so that it can be cooled quickly (this can mean packing thin meat cuts and surrounding the container with ice to get it down fast), and get it in the cooler/fridge. The last thing you want it to have is a warm core temperature.
If you are planning to cook for a large group especially with your own MKT, I'd recommend taking a Food Safety Class first (if you haven't already). For those of us who only cook for themselves or their immediate family but dream (or can only dream) of one day owning an MKT, here's a PSA:
http://homefoodsafety.org/safety-tips
http://www.foodsafety.gov/
http://www.eatright.org/Public/content.aspx?id=10948
