leaking throttle lock assembly over fuel pump
6wdcummins83
Hudson valley NY
I have an '83 m925A1 My throttle lock assembly is leaking substantially over the fuel pump. Its really only happening under pressure. Is there a gasket set i can get to fix it or can i get that individual part assembled or rebuilt anywhere?
porkysplace
1,486
mid- michigan
You should post a picture of whats leaking or the part number from the TM,s
6wdcummins83
Hudson valley NY
ok sorry for the mis-information I was panicked after seeing the leak in the dark, the leak is actually the emergency stop mechanism. The cable arm is loose from wear and it leaks from around the bolt
