skinnyR1
- 16
- 18
- Burlington CT
My heater core sprung a leak. Does anyone know of a replacement civi or aftermarket heater core, that will drop into the box?
Or match it up with something that will fit.Not to squash a possible sale, but a radiator shop may me able to repair your core.
Unless I can find a new replacement, I may take you up on that. Thanks.I have a used take off I will sell for $40 + S&H.
I havent looked to see the failure mode just yet. It was putting steam into the cab on my return trip and dumping coolant into the engine bay, so I just turned the valves to isolate it off.Are you unable to solder yours where it failed?
So could it be something as simple as a loose hose fitting?I havent looked to see the failure mode just yet. It was putting steam into the cab on my return trip and dumping coolant into the engine bay, so I just turned the valves to isolate it off.
So far, no luck finding a civi replacement. Non on that list are a direct drop in.List of heater cores by dimensions: http://www.google.com/url?sa=t&rct=...=5TFfouAm3E1g_BV1Oyxj9A&bvm=bv.74649129,d.aWw
