- 2,136
- 613
- Davis County, UT
I realize that there are a lot of threads on this.
I have stock 9.00x20 NDTs, and my deuce does have the extra weight up front of a winch. I check tire pressure regularly and run them per TM specifications of 50 PSI. Due to outside wear, or cupping, of the Passenger Front tire I thought I had a front alignment toe-in issue. I jacked up both passenger and driver's front tires, and spun the tire while holding steady a piece of white chalk to tire's center.
Basically followed:
TM 9-2320-361-20
Page 674
View attachment TM9-2320-361-20_Unit_Maintenance_pages_674&675.pdf
(except instead of moving the whole truck, I moved just the tires)
I measured from inside to inside chalk lines between passenger and driver's side tires at as the TM specifies at about 18.3" from the ground, both front and rear of the tires. I even spun the tires to measure from the SAME spot both front and rear. Each time I came up with about 67 3/16" (+/- 1/16").
To me, this says that my truck has excellent alignment. So I don't know how to account for the severe wear, cupping, on the outer tread of the Passenger Front. (yes, I've read around here, see below)
The Driver's front shows a little cupping on the outer tread too:
I've read varying opinions/suggestions on SteelSoldiers; one fellow reported that he never got more than 5,000 miles out of his NDTs when using his truck as a daily driver (I'm not sure if he meant ALL his tires, or just his fronts). AceHigh suggested "I think it is the drive train pushing the truck thataway while you are turning thisaway."
http://www.steelsoldiers.com/showthread.php?68910-M35A2-Alignment
This thread started by maddawg308 in 2009 seems to mostly suggest wear due to scrubbing, and said wear can be reduced by locking out the inner (center) axle, decreasing speed of left turns, increasing front tire pressure, and possibly switching to radials:
http://www.steelsoldiers.com/showthread.php?41220-front-tire-wear-on-the-deuce/
There also seem to be conflicting reports on the helpfulness of replacing the front shocks. (I haven't taken my shocks off my truck to test if they're still good or not. However, they're not leaking but, I'm sure, they are old).
I also haven't done any tire rotating - I've only put about 1500 miles on my deuce in 5 years. Here's a couple of shots of the rear axles (passenger side):
If I had to guess, it would seem like the most effective resolution is "most of the above", as cranetruck put it:
http://www.steelsoldiers.com/showth...r-on-the-deuce&p=455996&viewfull=1#post455996
Has anyone's opinions changed in the matter regarding resolving/reducing front tire cupping?
If I'm not keen to lose a rear drive axle (via performing the inner axle lockout) should I be changing to singles sooner, rather than later? My plan was to still keep duals on the rear but go singles on the front - Will excessive tire wear still be an issue in this setup? My plan was just like this fellow's rig:
(Michelin 11.00R20 duals in the rear and 14.5R20 singles on the front)
Thanks!
Basically followed:
TM 9-2320-361-20
Page 674
Since Cabell mentioned the article, it's "Front end alignment" , Issue #105, October 2004.
I have little wear on my front tires, about 1/32 for every 1,000 miles and attribute it to the following:
1) Check alignment and replace the shocks to dampen high frequency vibes. Check the leaf springs for sag.
2) Free up the rear bogie, the two rear axles are coupled w/o a differential and will force the truck to go straight on hard pavement, causing front tire scrub in every turn.
3) Single out your truck to lessen the tendency to force the truck to go straight.
4) Keep higher psi for the highway than specified in the TM. I use 70 psi for the hwy.
Thanks!
