- 1,711
- 1,794
- Nova Laboratories, WA
Bumper and aux LEDs installed for trip..
For a temporary fix , with 2000 miles ahead the air dryer needs to be serviced .Not that I know of get some WD 40 spray up into release valve and work the valve should help
Was it the small safety relief on the side of the air dryer? Had one of those go bad on me once. Good to have it there though. If your ppv were to fail and you didnt have that safety air pressure would just build until something burst.
Yes.Are you sure its not the expello valve on the bottom center of the air dryer getting stuck? You can stick your finger in there and push it back up.
I have zero pressure. Primary or Secondary. Pump is working over pressure valve is popping every 3 seconds.Do you windshield wipers work?
