gcbennet
- 8
- 18
- Trenton, ON
These things are rated at 17 MPG so that's probably the best you can hope for.
17mpg sounds awsome to me!17 mpg for full time all wheel drive in a 5200 lb truck with the aero of a house is not bad at all.
how do the 3speed 6.2's compare to the 4speed 6.5's?Not as bad as a 1:1 TH400 aka 3L80 trans
I bet a 700R4 or 4L80E swap would net 1.5-3 mpg better based on the fact they have a overdrive 4th gear and lock up on the converter, slip does not equal efficiency
Wow! a full quart? seems like that would make a big difference.if you are worried about it add a quart of 10w30 oil or 2 stroke oil to a full tank and call it a day.
Your tires seem to be different on the left vs the right?new doors and top. new rear seats and front and rear seatbelts. new oil pressure and tempature gauge. tires were as delivered 76800 miles on the truck
Any advice on doing a 1" or 2" body lift? Ive read the post on making a 1" lift: "Making a 1"HMMWV Body Lift".You only lift the body...not the suspension.
83 is more like what I have between the tires on the trailer.if your trailer is 84 like you say it will fit no problem..... 82 inches is what a 7500 gvw uhaul is in between the fenders to make the squeeze easyer inflate the tires up.
did they say anything about your tow vehicle and trailer load when you rented the trailer?07 ford f150 5.4 4x4 was the tow vech. it should go on at 81.5 width but it would be tight..View attachment 582337
the reason I asked about the tow vehicle is because the "rental company" seems to have an issue with my 5.9 High Output 4x4 dodge 3500 crew cab dually being "too light". and that the HMMWV is "too wide" for any of their trailers. something about their insurance...This has been coverd in depth in this and other threads.![]()
